vwcanuck said:I lowered my 68 a few inches with only beam adjusters.
https://www.thesamba.com/vw/forum/viewtopic.php?t=64301&postdays=0&postorder=asc&start=0
zerocool said:Im in the same boat at the moment,dropped spindles and an adjustable axle,seems like the best way to go
only problem we both have is we are running drum brakes with wide 5stud pattern,which makes droped spindles more expensive
you could use later dropped spindles which are cheaper and then use wheel adaptors to go back to 5 x 205 stud pattern,but the only problem with this is, it will push the track quite a bit wider on the front
joaonar said:zerocool said:Im in the same boat at the moment,dropped spindles and an adjustable axle,seems like the best way to go
Hello. I'm pretty much in the same boat as you both are. The big difference is that I already have some of the parts that I want to use: a pair of dropped spindles for disc brakes with latebay callipers. This will drop the front by at least 6 cm's but will increase the track 1 cm each side. If you want to use the early pattern, then you can add in fact, a pair of adjusters but this will increase the track even more. To avoid rubbing on the inner side of the wheel arch, then you will need a narrowed beam. I guess that a 3 inches narrowed beam will be more than enough for having all the front suspension, even with this updates, with an almost original track width.
The issue I'm having now is to decide which beam to buy since there are some to choose from.
Sorry for my grammar mistakes. English is not my first language. Cheers!
Hubs said:vwcanuck said:I lowered my 68 a few inches with only beam adjusters.
@vwcanuck
If lowering say 2" would there be much difference in ride quality and would the bump stops need to be removed?
