Looking really good in the engine bay, very neat. I'll probably remove mine as well. Are you going to put any sound insulation in?
gas1man said:I bought a length of board from B & Q that you use to go in front of a radiator in your house.
It's nearly the same just the holes are a little tighter together. Sprayed it black.
https://www.diy.com/departments/cambridge-large-white-traditional-radiator-cover/153462_BQ.prd
This is the sort of thing I used and some new fibreglass insulation between.
Hope the idea helps. Bus is looking good.
J & P
fallingoffalot said:Looking really good in the engine bay, very neat. I'll probably remove mine as well. Are you going to put any sound insulation in?
fallingoffalot said:I was looking at the thick (10mm+) under bonnet insulation.
This type of thing: https://www.deadening.co.uk/products/silent-coat-noise-buffler-30
67panel said:Most plug sockets are too thick in wall and jamb on cylinder head , I have a thin wall UJ one
67panel said:Yes it is a Snap on but 20years old!!
Dirty Harry said:Top notch work 8)
