Not posted for a while!
Been on holiday and too busy to sort any photos out.
Anyway I've stripped out all the interior and scrubbed all the old glue off, cleaned out behind all the door cards, looks amazingly clean and solid inside!
Have repairs the broken springs on the front seats and sent them off to the trimmers for new covers (black vinyl with white piping)
Fixed the springs by using sections of bent hollow aluminium tubing and supported this with wire, should hold out well, its certainly improved the seats support.
Also been grafting on the body work, all the serious dents are now teased out and filled (used Fantastic filler, its amazing!! cheers Leon for tip) Have sprayed undercoat just got to double check imperfections then top coat. The blend between old paint and new is looking pretty good.
I'm not painting every blemish as you may as well paint the whole thing then, just trying to keep the patina where possible but remove the bad dents. Once I've finished these its off to the body shop to get the front panel straightened.
Photos soon! promise!
