I've fitted a 1776cc engine and 2 litre gearbox in my camper, I've taken it out around the block to check it goes ok and it doesn't. It really struggles up the smallest of inclines ( I ended up in first gear and it only just made it up).
The brakes aren't sticking as I've checked and renewed them, it all moves freely.
The timing has been done.
The carbs have been stripped down cleaned and rebuilt, checked all the jets are the correct sizes for the engine. They have also been set up correctly (I didn't do it)
I've also changed the fuel pump to a cb rotary one.
Any idea why the engine lacks power?
Is the gearbox the wrong one?
The spec of the engine if it helps:
1776cc barrels and pistons,
engle 110 camshaft or similar,
CB performance 044 cylinder heads,
Dellorto DRLA 40 carbs,
Vintage speed exhaust,
Flamethrower distributor and coil etc.
I've got the feeling the person I got the 1776cc long block from has ripped me off, I'm beginning to think it isn't a 1776cc. I'm thinking this because the spark plugs were black when I took then out, over fuelling perhaps?
If anybody can suggest what's wrong with the engine that would be great as I've had enough of the camper now, its been nothing but grief and money since I got it.
Thanks in advance for any advice
