Graham L
- Joined
- Jan 19, 2008
- Messages
- 5,361
- Reaction score
- 304
- Location
- Bolton
- Year of Your Van(s)
- 1971
- Van Type
- Hightop Panel
OK after the prompts on the other thread heres the start of a new group buy of the Firetec Fire Extinguishers,
Spec as follows:
Specifications for use in VW T1 / T2 campers.
Cylinder: model B1. 300mm (with valve) x 90mm diameter. 1.25 litres aluminium.
Tube: 3.50 metres 6.2 x 4.0 heat sensitive REACTON 80.
Valve: Stainless steel Firetec Axial valve with easy top-up external Schrader, safety pressure gauge, and tube connections.
Bracket: Wire transport bracket with countersunk bolt kit.
Extinguishant (default): special mix, 9% AFFF, non corrosive foam.
Installation options:
Upright on LH chassis leg, horizontally on LH chassis leg or horizontally under engine compartment ‘roof’.
Buyer must state if under-roof configuration is required.
Instructions:
Standard CT instructions with extra page specifically for VW T1/ T2 campers included.
Requires good general DIY skills, but no special tools.
Price for Extinguishers = £140 + VAT = £161
Discounts as follows:
1 to 5 units: 10%
6 to 10 units: 20%
11 to 30 units: 30%
OPTIONS:
Chafegard:
Protects the tube from squashing and impact. Does not interfere with detection and discharge. Does NOT protect from sharp edges which can protrude between the coils. Can short wiring. + £18
LEDs:
n/o switch is closed under pressure. When the power to a green LED is routed via a n/o switch (and a fuse) the LED stays on when there is power, the wiring is intact, the fuse is OK, the LED is OK and the pressure in the cylinder is above 5 bar. + £20
n/c is open under pressure and only closes completing the circuit when the pressure drops. Thus a red LED in that circuit will only come when the pressure has fallen, providing that the battery, wiring, fuse, and LED are all OK. If choosing a red LED circuit you should include a test switch to bridge the switch contacts to check that the red LED and wiring etc. is OK.
There is no discount on the options but they need to be ordered with the batch, + £20
So prices work out at the following:
1 - 5 Units = 10%.............£144.90 inc VAT + Chafeguard =£165.60 inc VAT + Switch & Chafeguard = £188.60 inc VAT
6 - 10 Units = 20%...........£128.80 inc VAT + Chafeguard =£149.50 inc VAT + Switch & Chafeguard = £172.50 inc VAT
11 -30 Units = 30%..........£112.70 inc VAT + Chafeguard =£133.40 inc VAT + Switch & Chafeguard = £156.40 inc VAT
I'm happy to fund the £15 delivery charge to the one central location which will be our unit in Tamworth, with collection from there or delivery to shows, these cannot be sent out in the post.
So if you are interested please add to the list below with your requirements, need to know whether its upright/horizontal/roof, whether chafeguard is wanted and which switch if you want one (see description above)
1. Graham L - Upright + Chafeguard + n/c Switch
Spec as follows:
Instructions:
1 to 5 units: 10%
6 to 10 units: 20%
11 to 30 units: 30%
OPTIONS:
Chafegard:
LEDs:
