kevinhall
- Joined
- Sep 28, 2009
- Messages
- 277
- Reaction score
- 1
Picked up our 72 crossover dormobile at the weekend and unfortunately ended up finishing the journey on a recovery truck Ran beautifully for 200+ miles, then ran out of battery.
Took the battery out on Sunday and hooked up to a charging system and had a look around at the general wiring to see if there is a problem and it looks a bit of a mess with half chopped loom everywhere, wires not attached to anything. So questions:
- the dynamo/alternator wires dont go to a regulator, is there a simple way of checking first whether it is a dynamo or alternator and secondly whether it has an internal regulator?
- the positive wire from the dynamo/alternator goes into a juntion box, which then splits the positive feed with one wire going to a box just at the right corner of the engine hatch and the second feed going to the battery. Is there normally just a direct feed from the dynamo/alternator to the battery. What is the box above the engine hatch? Seems to have the interior loom etc leading off it so is it just a junction box effectively?
Any help appreciated!
