Sharkyrayner
- Joined
- Nov 20, 2012
- Messages
- 64
- Reaction score
- 0
Has anyone experienced main beam failing to work off of the indicator stalk. Main beam used to work and operate the relay when the headlight switch was operated twice. This option has stopped working so I have changed the switch, no change then the relay with no result. However the main beam does work when the 5th terminal on the relay has a wire attached but headlights are not an option then. Any ideas as I've got an mot booked for Friday?
