F frenchi Well-known member Joined Sep 27, 2013 Messages 49 Reaction score 0 Mar 31, 2023 #1 its my 71 bay 1600 cant get no spark new disi new coil new electric ignision got 12v to coil checked all wires i can think off any idears welcome
mike202 Well-known member Supporting Member Joined Sep 3, 2011 Messages 2,529 Reaction score 583 Location Northumberland Mar 31, 2023 #2 Try your old dissy see if that works. If you’ve checked everything else; battery, leads, coil etc then it could be a defective dissy. You may be able just to swap some points in if you had them after taking out the electric module.
sparkywig Administrator Staff member Administrator Moderator Supporting Member Joined Feb 9, 2008 Messages 12,617 Reaction score 1,297 Location mostly here, sometimes there Mar 31, 2023 #3 Put the old stuff back in and see if that works. If you have reversed the electronic ignition connections you've probably blown the module.
F frenchi Well-known member Joined Sep 27, 2013 Messages 49 Reaction score 0 Mar 31, 2023 #4 as allways many thanks will try
sparkywig Administrator Staff member Administrator Moderator Supporting Member Joined Feb 9, 2008 Messages 12,617 Reaction score 1,297 Location mostly here, sometimes there Mar 31, 2023 #5 Let us know how you get on.
