Not mine... But I love it...
excuse me viNce , is it possible to have the same panel but for men :mrgreen: :mrgreen: :mrgreen:
sorry, it's a joke and I'm sure he understand :wink: :wink: :wink:
i get the joke even in translation.
can you provide some details of your brake/wheel setup? are you running porsche discs up front? or bay drums/discs with spacers?
are all cookie cutters 7J? im asking as ive just got a really good set cheaply, i was thinking running the porche pattern drums from C and C on the back but wasnt sure whether to go standard bay discs and spacers or try to source a porsche disc setup from the breakers yard and modify this?
has anyone got porsche discs up front? are they hard to fit?
Hello Johnny
I'm running stock front and rear brakes, I've installed my cookie cutters with Vw to Porsche pattern homme made adaptors (20mm Thickness).
All are 6J*15" wheels with 195/50/15 front and 195/65/15 rear...
There is not so much space between the rear wheel arch and the tire (~1 finger :roll: )...
Mister 16' I know that you love my bus but I'm sorry, not for sale.. for now :mrgreen:
Hello, I left you with my nearly done new 1775 engine, I ran great...
http://video.google.fr/videoplay?docid=4745379291673522509
http://fr.youtube.com/watch?v=DDzosC0peQ0
... until I broke the case on the rear hanger mounting bosses after 8 months of very hard driving :mrgreen:
tried to repair it but no success :cry:
So I will replace my gearbox by a 73/79 bay garbox witch has the two holes on the clutch house, and I will weld the late bay gearbox support on my bus in order to have it firmly maintained to avoid future case cracks...
So my bus is in my parents house @ 700 km away from I live... I'll work on it in July after the EBI#2 & August as I now a teacher, I have long vacations 8) 8) like pupils :lol: :lol:
Because my new gearbox will befirmly maintained, I decided to start another new engine :D
So I tore down the 1775, welded the broken case which is now running great un a friend beetle...
All was in excellent shape even with my driving style :lol:
So I started to collect all parts to build a 2074 engine (78*92 thick walled P&C), I only kept my Steve Tims Stage 1 heads, Big beef manifolds, the damper pulley, and my 40 DRLA carbs, from the 1775 all the other parts are new...
Here are the engine specs:
Case : AS41 mag case full-flowed bored for 94 mm cylinders.
Crank : 78mm Flat4 4340 Chromoly, all VW journals, AA 36 mm Chromoly gland nut.
Flywheel : 200m stock weight VW forged, 8 dowelled.
Clutch : KEP Stage 1 & Daikin super disc.
Chinese damper pulley (the black one)
All balanced separetely and together
5,4" DRD I beam rods, Clevite77 bearings.
Pistons & liners : AA Performance 92mm Thick Walled matched weights.
Camshaft : Custom DRD camshaft started from a Scat SC1 blanck sent to Engle to have it machined FK43 intake/FK7 exhaust.
Lifters : Scat lube a lobe SLR regrounded.
Scat Manton Thin Wall chromoly pushrods.
DRD 1,4 :1 rockers.
043 Steve Tims Stage 1 heads.
CB big Beef matched manifolds
9,5:1 CR, 0.04" deck height, 53 cm³ chambers.
30mm oil pump, steel full flow cover.
CB thin line sump.
Bugpack Street Max 1" 5/8 merged header, A1 Dynomax super-turbo 2" 1/2 muffler (will be replaced by a 1"5/8 sidewinder this winter)
Pertronix billet dist, with ignitor II, 45000V 0,6 ohm Pertronix Flame Thrower II coil, Pertronix 8mm silicone wires.
NGK BCP7ET spark plugs
Two Dellorto 40 DRLA carbs, 34 mm chokes .
Here hare all the collected parts for now, the other ones will be @ home before the end of July...
Reworked manifolds from my 1775, I match ported them in a better way than for the 1775, with a better straight design 8)
New engine bearings, Mahle mains & camshaft, clevite77 for the rods all VW journals,
Elring Engines Gaskets, sealing copound & flywheel seal, 34 mm vents for my carbs...
Flat 4 78mm crank, all VW sizes, near NOS stock weight VW flywheel
DRD 5,4 I beam rods same as CB unitech HD plus rods
CB thin line sump, I drilled & tapped the sump plate for an oil drain plug
Straight cut gears, HD gland nut & washer, 3/8" exhaust bolts
Oil galleys plug kit
First step, my rotating assembly was sent to the balancing shop
I'll keep you updated with some new parts that are living the Californian coast, and the engine building :D
Bye!!!
excellent stuff, i just dont know how anyone knows where to start specing out an engine!
Got some other parts, I'll start to build it tomorrow 8)
New Chromoly Head Stud kit
Scat Lube A Lobe SLR'ed lifters
New custom built Engle dual lobe FK43 intake / FK7 exhaust machined on a Scat SC1 blank to have a perfect cam/lifters adequation, this blank is also factory clearanced for the rods
New DRD 1,4:1 ratio rockers with Bugpack schims and lash caps
New 92's TW pistons & liners kit
New AS41 case which will be bored and full flowed on wednesday
I also received new ignition parts
Pertronix muti curves distributor
Pertronix 8 mm low resistance wires
Flame thrower II coil
All my engine parts are now collected, let's start to built it :lol:
Just waiting for a custom built all 304 stainless steel A1 Sidewinder exhaust 8)
mmmmm nice 8)
what diference is there in diameter of that pertronix dizzy and a standard dizzy? i was looking to fit a porsche fan kit but there doesnt look like there is clearance as the standard dizzy looks much skinner?
Hello I measured it :wink:
a 009 is 64mm and the Pertronix is 113 mm :wink:
Have a nice evening 8)
hello Johnny, I gave my pertronix to a friend who is building a Type& engine with Porsche Fan, look at the pics, it's too close but it can be installed.... with a shroud modification, you may be able tu run it.
Bye!
Excellent work sir. I love the smell of new engine parts in the morning 8)
cheers vince, i have a porsche fan style engine ordered and i think the pertronix will clip the fiberglas cowl, i have to wait and see. I wanted this type of dizzy as i didnt want to mess around with a 009.
Hello all 8)
Some little news about my bus,
The engine is in stand by because I'm waiting for a total seal second rings set and a missing scat chromoly long head stud, only 15 studs in the package :x
Here is the work that has been done :wink:
The case, back from cylinders boring
Some accessories
Matched oil pump/case galleys
All case plugs drilled and tapered
Machining for the crank and rods + breathing
Matched pistons weights
"Race" german oil pickup
Checking rings gaps
Checking endplay
Checking deck height
Case decked to the exact value
Fitting all tins before going for powdercoating
Going up to 57cc (50 before) on the heads to reach 9:1 CR
Working man 8)
and done
Replacing the 8 pass cooler from this
To this
Now I'm waiting for the missing parts to assemble the engine, all is checked and rechecked (clearances, plays ...) :mrgreen: just have to clean and install the parts définitely like à LEGO 8)
In parallel, I welded a late bus gearbox brace, it needs a lot of modifications but well woth it to avoid any future case crack like on my 1776 (posts above) :shock:
Cleaned
Sand blasted
Primered
Got a late bay "clutch house" (How do you call it in english?? :mrgreen: )
Cut cut cut
Check
Weld 8)
Cut :mrgreen:
Flying gearbox :wink:
Primer
Draw :mrgreen:
Cut :mrgreen:
Weld 8)
"shave"
And finally paint !!!
That's "all" folks :mrgreen: :mrgreen:
More pics on my blog (in French sorry)
astounding work! you seem to have all the right tools, really impressed on this build 8)
we call it a 'bell housing' in UK :wink:
Here is the second batch of pics as I forgotten to update this topic :roll:
Case machined to have the exact Deck Height:
http://www.youtube.com/v/Do8ErNI39Sc" onclick="window.open(this.href);return false;
Checking the new DH, with 1.2mm on all 4 barrels
Installing chromoly studs on the case for the rear hanger, more resistant than the stock system.
Finishing the fuel & breather lines:
Finishing the manifolds match porting,I bought my manifolds bare not reworked by Steve & Greg Tims
Setting the Rockers end play 0,1 mm on all.
Last view of the Steve Tims heads (home made reworked chambers to achieve 58cc as they came with 53 cc for my old 1775 and 50cc after the flycutt to accept the new 92 Thick Walled cylinders) & manifolds:
New Berg retainers to have more spring clearance:
Berg magnet:
Last "moke up" of the long block
intake Retainer to Guide clearance (1,5mm)
Full lift:
Valve to piston clearance at th most "critical" point, At this point I can move the valve (witch is without spring) on 2.5mm before touching the piston.
The last pics of my build, concerning the final assembly of the short block:
Installing the rods on the crank, streching is checked on each bolt after being torqued
Case closing:
ARP lube on the case bolts:
Installing the sump and others accesoiries:
Flywheel torked to 45M.KG
More accesoiries to cover all the holes...
Cutting to lenght the head studs
Installed:
Final assembly of the pistons & cylinder with TS second rings, cleaning:
Setting rings gap:
Assembly:
New springs:
Near to be ready to run with a Steve Tims head / 40 DRLA on the left and GB865 / 48 IDA on the right :lol: :lol: no that was just for the pic:
With its future owner on the background:
Back on the track,
Reworked keepers (they are not touching when installed)
Checking for coil bind:
Now the engine is just waiting me to coming back from Paris to reinstall the valves on the heads and the heads on the short block for the first start, the new exhaust is also nearly to be finished by A1 & shipped to France 8)
Bye!
Vince
