doz
- Joined
- Jun 9, 2011
- Messages
- 398
- Reaction score
- 0
I knew I was in for some teething issues when I got the bus back on the road but this is getting silly now. Went to move the bus this afternoon and the oil filter appears to have split around it's plate where it screws on. I caught it straight away there's no damage to the engine I noticed the oil pressure dropping back on the gauge. Now I do run a uprated oil pump and full flow case. The oil filter lives under the nearside corner and is in line before my remote oil cooler. I did the first hundred miles after engine rebuild using straight 30 weight oil When I changed from a Bosch filter to a champion one I changed the oil for a hi quality 20-50. I drove the bus with this oil and filter for about 10 miles last night without issue. When the filter split the bus was warming nicely so the pressure had settled down to it's normal operating pressure of around 60 psi. The filters I use are for a Mk1 Golf 1600 which running hydraulic tappets will normally see oil pressures between 60-100 psi. So I thought I had covered every base so as about of litre of finest oil splurged all over my nice clean driveway the language did turn mighty blue.Have I done something wrong in the configuration? Or has the 20-50 oil raised the pressure enough to split the filter (which it hasn't according to the gauge which has proven very accurate when compared with my mechanical workshop gauge) or have I just been unlucky with a duff oil filter?
To recap.
Engine oil pressure:- Cold start is 100psi approx. Soon settles down to 60 psi at revs above 1500. Once warm idle oil pressure is 30psi approx.
Filter is mk1 golf 1600 (think your find it's the same filter used on the 1800 mk 2)
To recap.
