Pain in't arse
Thanks for the link. Just ordered one, for the price its worth a try, plus - have had enough of getting stranded without fuel.
Can't wait to see your van ready
Finished cab floor used some metal from JK floor panels which were crap as you can see the indent is not the same no matter its only a minor detail in the scheme of things
Hopefully I can give the cargo floor a 'blowover' this weekend and then i get the carpet and panels retrimmed - I have a aversion to plastic vinyl, I like 'warm and furry'!
Still sans engine but I have now finally got everything I need for the engine so maybe a couple of weeks - maybe - knocked up a 3 gauge pod though so i can monitor the engine
The good thing about having no work is I get time to bugger around with the van, the bad thing being able to afford to bugger around with it, bought a load of scrap metal and some knackered and rotted heat exchangers - can i be arsed messing around with some crappy repro's
Engine still a way off but i have almost all the bits, maybe a tad more shim currently 0.007mm
On the plus side i have mastered the ancient art of putting metal trim after the window is fitted, there is a knack to it - which is probably don't bother and fit the trim in the rubbers before fitting the windows, I shall go around replacing all the rubber and respray the surrounds as i go - the bottom half can be done when i can be arsed! it's all about getting the baby on the road as i need it for work
Busy, busy it will be running/registered soon after much scouring the engine is almost together apart for some bits for the full flow oil filter that are needed
A bit of delicate surgery to run a cable down to the rear seat speakers was required
On to the door cards and rear seat enclosure, using 4mm ply for the door cards and probably use the same for the head lining, need to find someone to uphoslter my bed - inexpensively like! :50:
Nice work Adey. Definitely getting there. Can't beleive how quickly you've picked up all of this air cooled malarkey. Hats off to you my man. :D
