So after some fairly poor mpg and a new 4:1 JK exhaust, I got the carbs checked on a rolling road. They found the carbs to be set up OK he richened up the idle mixture a little on the left as he found cylinder 3 to be quite lean, which he said was common and did some other minor adjustments.
He also recommend getting some velocity tubes as this will flatten out the dip in the power.
The drive home felt more responsive and it pulled away better. I filled up again earlier after about 120 fairly fast motorway miles and found I'd got 21mpg. Better, I'm putting the 16.2 I got down to driving enthusiastically round the Cotswolds!
Not sure if vids can be embedded on here - here's a link you YouTube...
[youtube]https://youtu.be/D21JAqqsrhs[/youtube]
