K@rlos said:Creative engineering do a kit but it’s a load of dog **** and takes a lot of re engineering to make work right. In the fullness of time I’ll be going the Porsche 944 route for mine to match the front.
cunning plan said:K@rlos said:Creative engineering do a kit but it’s a load of dog **** and takes a lot of re engineering to make work right. In the fullness of time I’ll be going the Porsche 944 route for mine to match the front.
Sorry to be lazy, but do you have a build thread or specific page for the 944 front disc brakes? oke:
joneastwood said:Made my own kit
944 on the front
home made rear kt all from parts off the shelf apart from the adaptor bracket to hold the caliper
plus had to have some machining done to get stuff to fit together but the set up is awesome now and don't feel I need a servo
:mrgreen:
K@rlos said:cunning plan said:K@rlos said:Creative engineering do a kit but it’s a load of dog **** and takes a lot of re engineering to make work right. In the fullness of time I’ll be going the Porsche 944 route for mine to match the front.
Go through my buses thread it’s on there
Regarding is it worth doing? yes most certainly, the actual braking force won’t be noticeably better however self adjusting cailpers and brakes that don’t fade going down long or steep hills and ease of servicing make worth while. If rear discs performance wasn’t up to a certain level all cars & vans would still have drums today.
Yes I have a big power motor in my bus but the stock brakes were **** when I had a stock engine.
gagvanman said:What handbrake cables have been used on the rear disk conversions?
joneastwood said:gagvanman said:What handbrake cables have been used on the rear disk conversions?
i used og ones but they come up about 400mm short but just used a joiner piece to fill the gap
Haveacamper said:joneastwood said:gagvanman said:What handbrake cables have been used on the rear disk conversions?
I have similar. If you are not happy to this, you would find out how much you needed to lengthen and shorten and contact someone like speedycables who should be able to make you up a custom one for you.
