Rear suspension drop. Inner n outer splines etc.
RICH-I-AM
Jul 31, 2008
2,449
UK
Evning all :mrgreen:
Sure this question has probably been asked a million times before but.....
What drop at the rear can you expect (in inches) from
1. 1 outer spline?
2. 1 inner spline?
I only want a subtle drop, an inch or so.
If i need to use inner splines can it become a nightmare.
Thanks in advance
Rich.
Cheers loxy 8) .
How easy is it to judge 1 inner spline when the bar drops out?
The outside is easy enough, and im sure the inside is just the same, all i would say is make sure you know exactly how many you are going either way before you start, and try the outside first, just to get a feel for how they move, also mark your starting position first, i would even go as far as marking the arm against the chassis of the van so that you can put it back to standard if you want.
good luck, i would personaly fit a set of aftermarket lowered arms too
Cheers for your help people.
Went down 1 outer and looks fine. I want a set of rear adjustable spring plates, will be getting them when money permitts.
Rich
Rich
And the pics are where exactly???????
:lol:
Rich
:lol:
I will let you off - just seen them on the other thread ;) :lol:
