Araon
yeah thats what i thought but the shafts the easiest part to manufacture from scratch and be sure of its integrity...
Araon said:So how are there spindles manufactured? there not welded, so cast? so why do they want the old spindles at that price?
loweredlight said:The more I read the better the Red9 kit sounds, but just so I get this straight what's the general concensus of opinion for a smooth safe ride:
Dropped/welded spindles
or
Red9 coilover kit
Cheers for your thoughts.
Dave
froggy said:They agreed that in principle it was a good idea but should only really be fitted to single / crew cabs as they dont have the weight of a camping interior sat inside.
This sort of convinced the wife that adjusters are the safer way to go but i'm still not sure.
cyberdyne systems said:loweredlight said:The more I read the better the Red9 kit sounds, but just so I get this straight what's the general concensus of opinion for a smooth safe ride:
or
Red9 coilover kit
Dave
I'd say not one verses another but the two combined, the red 9 for a good ride and dropped spindles for balljoint travel. I wonder if Red9 can do a 0 - 2" if you wanted to fit these new 3.5" dropped spindles to get a total drop between 3.5 - 5.5"?
Gareth
loweredlight said:Hi guys I think I'm going to go Red9 route, but could somebody tell me how you fit there bumpstops.
Dave.
Hope this is the case, as i was under the impression that they were different, if not then i can upgrade the front brakes / discs to the later type at the same time as maybe looking at dropped spindles.Graham L said:As far as I'm aware your 71 only spec only affects your brakes and the spindles are the same as following years,
I'm sure someone will correct me if I'm wrong![]()
I fitted the different caliper mounts and the later (cheaper!) brake calipers just thought that i would eventually fit the later (cheaper) discs.Araon said:71/2 differed in the caliper mountings....but to fit the later brakes a spacer can be fitted to 71 spindles or just fit the later spindles with the latter brakes a lot cheaper route....
Had planned to until i read about the wagonwest group buy on dropped spindles :lol:cyberdyne systems said:Bloody hell just go for it Froggy! :mrgreen:
froggy said:Had planned to until i read about the wagonwest group buy on dropped spindles :lol:cyberdyne systems said:Bloody hell just go for it Froggy! :mrgreen:
Thinking that once i've dropped it then it will stay at that height and as i was only looking at the 2-4" kit then maybe a 2.5" permanent drop might be easier :roll:
