Quincey
Howdy all.
I have recently replaced the window seals (VWH) on the cab doors and they took some doing as i'm sure anyone who has completed this task will attest. They appear to be inserted correctly and look watertight. After a massive downpour today, water was seeping into the door cavity (door cards are removed at the moment).
My question is, will there always be a certain amount of water that will penetrate even with new seals installed?
Is this the reason for the drain holes in the bottom of the door and the plastic sheet between the door and the door card?
Any hints will be welcomed.
