Ryanmck1984
I've finally found the time to start fitting a pair of original seats i got hold of. The existing seats have been welded in to place! So far after about 5 cutting discs and a few curses it's getting there....but....there only seems to be one bolt hole to hold the passenger seat at the rear right if you were sitting on it. Everything under the steel bar looks original. Just wondered if you guys had any idea?
The drivers side look a bit more normal. Is this the correct length of runners and is it just a case of sliding the seat in? cheers
