Eeza
My van is a little slugish to pull top gear and I am thinking the timings out, now I will get myself a timing light but thought I would make sure the STATIC timing is set there abouts before hand.
In this attached image the static timing marks for T2 1600 engines are shown, however I have a 1973 sticker on my fan shroud and the engine is a bitsa motor with AS cases so no real idea of its origins, question is where should the timing be set static at 7.5 / 10' BTDC for my engine ?
Its easy to do with a test lamp and my pulley has 3 marks TDC 180' to TDC and a mark at approx 11pm to TDC if you know what I mean. Its a TP with the dreadded 009 and Pict 34 combo :shock:
