Geeee suss George, You are an out and out , one hundred per cent, died in the wool, genuiiiiiiine, made to measure, absolute Genius :idea: :idea: :idea: . I didn`t even think of auto correct , :roll: Now is that because you are way way way below the age of fifty and I`m way above the age of fifty
So you got two screws at the door end and that`s one in and one out side. You should have another outside at the opposite end by the air vent, you`ve also got the nut on the threaded end by the door outside and you also have the tension from the bumpy bit that is connected to the threaded end. That`s all the fixings I guess.
Then you got the plastic / vinyl gasket between the cover and the body, now all of that is brilliant but mostly it`s `nature`helping to hold it together were natures own brand of adhesive,,,, `Rust`. The way I`d go about it, is spray a decent penetrating oil over all the fixings and anywhere you can get in especially around the bumpy strip, something like penetrol, not WD40. Leave it soak overnight then do it again. Loosen all fixings and tap the threaded bar back towards the vent. If I don`t move, soak it some more as you might get a little more in if you`ve moved it a tad. The bit that the bumpy bar sits in which is like a U channel and flat on one side and a negative of the bumpy bar on the other.
So from a side profile you have the side of the van, then the flat side of the U channel then the plastic / vinyl gasket then the flat part of the side cover then the bumpy bar with the threaded drag bolt at one end then the other side of the Uchannel complete with bump negatives.
So get a thin scraper if you can`t budge anything and try and gently push it into each side of the plastiky gasket and lever bit by bit and every time you move it a bit then get some more penetrol into it. Once you`ve separated the gasket and generally worked it up and out,then you`re home and hosed :mrgreen: :mrgreen: Don`t try a blowlamp
Ozziedog,,,,,,,,,,,,,,,,,,,,,, So how do I know this :mrgreen: :roll: :mrgreen:
