Dennis said:
Please explain why this should be a scary-setup??
can you explain why it
isn't a scary set up ?
genuine question, no hidden irony or sarcasm... are you a suspension expert ? can you categorically state that a modification of this kind IS safe ?
i think there are lots of us out here in 'fiddle-land' who are looking for the ultimate in bus lowering kit... i too have spent many a long hour trying to think of ways to get the thing safely down on the floor, and i've come to the conclusion that i don't like any of the available 'bolt on' lowering stuff for bays.
i don't like welded spindles, i don't like horseshoe plates, i don't like notched springplates, and i don't really like the look of these spindles either.
i'm no 'expert' and my terminology may be a bit askew here, but in the majority of suspension set-ups that use balljoints, is it not true that they're in 'compression' so to speak, both the top and bottom one, or the top one is in 'compression' and the bottom one is in 'tension' ?
in this set up we've got the weight of the bus being supported by the threads on those four balljoint 'stubs', and if those threads aren't up to it, and they might not be, if the balljoint wasn't designed to be used *upside-down* as it were, then goodbye steering knuckle.
OR
and it's a big OR, are these special balljoints that have been manufactured especially for this application, which have the tensile strength to hold up the bus and then some ?
this is where speculating on an internet forum is a bit of a waste of time, especially if you haven't got all the facts
i'd like it proven to me that they're 100% safe however, rather than me having to prove that they're unsafe if you see what i mean :wink:
