Louis
Got it running again, now hopefully slam will occur next week. Knock on wood
Louis said:I did run into a problem when I went to lower the bus the rest of the way. I dropped it 2 upper adjuster teeth and 4 lower adjuster teeth (I'm running KP/LP 4" narrowed with spindles btw) and when I did, it was impossible to stear the bus. It was so hard to turn, I started to rip the new rag joint. I looked under the bus and there was nothing touching or rubbing, tires were close but not touching and the tie rods were miles away from anything. When I lifted it back up to where it was, it turned fine.
I was thinking it might be caster but I dont think caster would make it THAT hard to stear plus it was equally hard to stear in reverse. The only suspension pieces that change angle when dropping it are the tie rods and they werent hanging up on anything. I have noticed that when there is a heavy load when the beam is adjusted up, the steering gets more difficult as well, but nowhere near this bad.
Has anybody had a similar experience or any idea about what might be going on? I wanna slam my bus more.........
Its a shame, it looked so damn good that low and I was too distracted/discouraged to take any pics of it.
Louis said:Wow, I need to go check that out! Theres a good chance that whats goin on. Any fix for it that anyone knows of?
And dubscum, your buddies late looks damn cool. now to get it on the ground..... lol
LEEP said:Dude, that thing is dumped. 8)
Instead of trimming down my mustache bar I just bought this:
http://www.royrogersparts.com/vw211-199-203b.html" onclick="window.open(this.href);return false;
It's only forty bucks and if you spend ten more dollars the shipping is free. Totally worth the time and effort saved.
