andynods
- Joined
- Mar 24, 2007
- Messages
- 199
- Reaction score
- 0
Hi All,
I am wondering if you can help. I am hoping to go camping in about ten days time and may not be able to go if I cannot sort out my sliding door!
Basically, the door is a bad fit as it has been badly repaired at the bottom six inches and so this is in play. However, it has been like that since I had it (six years) so I know that is not all it is.
The door has deteriorated over time from closing fine, to needing a good slam, to the 'turn the handle up to pull it in' becoming less effective to the point now where it either won't close at all or pops open (front and back) as you are driving along. You are rarely able to get further than a few hundred yards, often a lot less!
I am trying to remember whether it got worse when I got the sills replaced last year - I just can't remember - but I thought I would mention it as maybe there is something to do with this causing things to not line up. I do think that if it had been a problem straight afterwards, I would have associated it with the new sill alignment so I do not think this is it either.
So far, I had the MOT garage (they know their VW's) take a look, who said they had made it better but then it only lasted a few miles (better than before) and then back to square one. I then got my VW aircooled specialist to take a look as part of the service. He spent two days on tweaking alignment and getting it better but I picked it up last night and no better really. He said it wasn't great as the door was misshaped (but has always been like that and problem not always existed) and the mechanisms were shot. He was describing how hard these parts might be to find.
Any ideas?
I would even be interested in a way to permanently lock the door so it cannot be used so I can go away and use the other doors.
I just cannot drive any distance with it popping open or with it tied shut with rope!
Any ideas?
