windsurfer
Having a problem with my bus, it wont start. Had a look underneath today and it's all a bit confusing:
It appears that there is an additional solenoid wired in series with the original solenoid, if I bypass the additional one using a piece of metal, the bus starts.
There are two high tension cables attached to each solenoid and one low tension (going to the ignition switch I presume).
I can't understand the reason why there would be another solenoid or why both would have 3 wires connected.
I have looked at my manual and all wiring diagrams show only one solenoid, any ideas?
Si
Si
