aogrady
Hi!
X2 PICT34's First one is ok condition, was only changed to cure a flat spot, which was still there afterwards, so has been running ok. Would benefit from a bush job and quick service with new gaskets to be really good. Was keeping this as a spare, but now going to twin carbs so now not needed. Looking for £25 for this one. (last 2 carb pictures)
The other one is ok for spares, a mounted bolt is missing, and the 5p sized back fire disc thing has been expoxied over. There is a screw fitted down the vac pipe for dizzy. Everything else seems ok, haven't took it apart, but ideal for bits if you need a base or top cover. Looking for £15 for this one.
Next up a couple of inlet manifolds for the 34 PICT 3, (now seems seem to have larger diameter heat risers than my rusty old one still on my van)
There is a take off blocked, suitable for a servo bus i would guess.
I have taken a close up of the casting number so you can work out what it's off.
Looking for £15each.
Also i have a stock oil bath air filter. Not too sure of model year, but again the picture with the part number may help. Complete with the black pipe that always seems to be missing. There is some tape on this so don't know how split it is if any.
Looking for £25
Prices plus posted at cost
Cheers!
Alistair
Looking for £25
Cheers!
Alistair
