Sound deadening in the engine bay Good or Bad
Buss69
Feb 19, 2007
625
7
West Sussex
Hi everyone, wondered what everyone thought about the sound deadening in the engine bay of out beloved buses. Being extremely paranoid of engine fires I have wondered if it is worth removing the hardboard and the insulation above and use something more modern and fireproof as a replacement. As far as sound deadening goes there are definitely better and safer products out there. I've also noticed that a few people have not replaced theirs in what is otherwise a very sound bus, why? I'm going to fit one of the FireTec extinguishers also but wanted a few opinions on the subject.
I removed the original "cardboard" liner in the engine bay and fitted Dynamat for sound deadening then fitted a pierced ally sheet over it so I could attach cable ties to it when I fitted the FireTec Extinguisher
I had nothing in there when I bought the bus, so I purchased special sound deadening foam that was heat and oil resistant. The foam has a special smooth coating on the engine side and after I had installed it in the engine bay the sound had sifnificantly decreased. I can now talk to a passenger without having to shout.
Don't think this stuff is available in the UK though.
Anyway, I can reccommend it.
Cheers dude. When you took off the cardboard what was behind it? What I mean by this was there any metal framework, strengtheners or bracing behind the deadening?
Cheers Resto,
How thick was your special foam, did it come from a performance shop or stereo supplier?
i got a sub it helps with the sound deadning although conversation is a bit limited,
and yeah there are strenghteners under my may
i have been known to cum back from the pub with wild true statements though :lol:
john the horse
john the horse
Pub wisdom :lol: where did you stick your sub out of interest, I'm assuming that's not a large baguette based sandwich :D
Interesting spelling of come John, shows where your mind goes after a few ;)
I bought the foam from a company that specialises in noise control, called Merford.
The foam comes in variable thicknesses and I bought the 25mm foam. It fits perfect.
The site is in Dutch but you'll get the idea. Dimensions and prices are listed.
http://shop.merford.nl/zakelijk_nederlands/acusticab-z.html
This is one half installed.
i bought 25mm celotex silver backed insulation foam used to insulate cavities and walls,fire rated and not bad for sound,then i fixed perferated alluminium sheet and fitted the firetec system.
dont know whether you can see it on my avatar pic. :roll:
:p
hope this helps.
not got one uploaded to photobucket of the process of fitting the celotex and the grid but this finished pic with with firetec inplace hopefully tells the story :roll:
:sick0019:
Cheers dude that explains thing a bit easier. That's a nice looking engine bay you're rockin' there. I've now opted for some aluminised foil style felt nonsense made by FireTec 100% flame proof, I'll post a few picks when I install. Thanks gents for your input.
