67panel
- Joined
- Jul 30, 2009
- Messages
- 2,776
- Reaction score
- 195
- Location
- malven
- Year of Your Van(s)
- 1968
- Van Type
- panel
All wiring sorted (I hope) ,rear lights fitted and my youngest lad came down and helped fit tailgate yesterday. Gearlever repaired , its a Scat one that was in the bus when I got it 20years ago and looked old then. Frame had cracked and bottom plate bent to **** so bit of hammer work a touch of MIG and splash of black should see it last another 20 or so. Gearbox fitted ,found cage for shift rod bent so it was a good job I have a new one. Wont go over shift rod bushes though so a bit of a fiddle tomorrow. Spent an hour looking for wingnut for clutch cable , gave up and ordered new but that was okay as needed to get new engine bay front seal and a few other things. Planning to repaint fuel flap and some bits that got scratched wet flatting that wont buff out on Thurs as its supposed to be very hot.Found all the bits to put flaps back in cooling , even a working thermostat !!! Manifolds have to come off to fit vac fittings so will clean carbs as well .
