Managed to get a day on the bus. Started by checking the water tank for leaks, and yes it did :lol: cleaned all the muck out the valve (which was jamed oped) and jobs a good 'un
modded the sink unit so I could pick up on the OG fixing using a T-bolt
Then Brett (Terrierman) came round with some structural adhesive and bonded the panel I made to the bulkhead. Thanks again Brett, a beer or two will be in order. The panel will be covered with material.
Next up, test and terminal the mains & 12V system, there is a aux fuse box here with the earth bar and connections at the rear.
Inverter under the sink
Zig wireing complete, and made a panel to house the Propex vents in the RNR front door.
Side cupboard put back together, which hides more wires
Fridge nice n cold
There were some scrates to the cupboard door, so used some fence paint to hide these, worked ok
Then installed a rear bed light,
and put down some dynamat type stuff
Nearly there, then I got to start on the cab doors, then roof & poptop canvas.................. :lol:
Just
