Valentine Won
Deffo
naskeet said:creationblue said:It's a Westy handle Paul for the reason you mention, most snap and unless you find another you will have to use a standard microbus handle, the second handle makes it easier to close in the dead of night when the usual roar of a Bay door sliding wont go down well with fellow campers :lol:
All of that noise can be avoided, by using a rear-mounted pull-close strap of "helper handle", the latter of which seem to have been relatively common, on "early-bay", USA spec. Westfalias
This is the sliding-door, pull-close strap, I made for my British specification, right-hand drive, 1973 VW Type 2, Westfalia Continental campervan.
This is made from a 25 mm (i.e. 1 inch) wide strip of duralumin and some 25 mm (i.e. 1 inch) wide nylon webbing. I used grey webbing, whose neutral colour blends well, with the pastel-white interior, but I also have, black, blue, orange and some other colours I think.
The two 20 mm long screws, use the existing tapped holes, in the sliding-door, rear hinge mechanism, as does the special OEM helper handle.
The main sliding-door handle, is obstructed by the campervan furniture, so this strap mades it much easier to close the sliding door and much quieter too.
If anyone is interested, I have some some materials left, to make up some more, for either right-hand or left-hand sliding doors.
creationblue said:Today I fitted Buttys throttle kit
I then went to Clevedon for the afternoon and the kit works a treat, great peddle feel now 8)
I cleaned the water tank and put some milk in the fridge and off we went....... Shame I didn't check the Gaz :msn4: yes it was empty haha, still, it was a nice dry sunny afternoon
*Sam* said:Just you can still buy the retractors i think from cool air.
robins said:i got buttys kit to fit and seatbelt things,engine,drive shafts,sliding door hinge,seals, :roll:
it will never get done
sparkywig said:robins said:i got buttys kit to fit and seatbelt things,engine,drive shafts,sliding door hinge,seals, :roll:
Better get your finger out Rich, 2 months to Bristol Volksfest....
Geeze said:Looking good 8)
And for reminding me about butty's linkage kit, was looking at mine at the weekend and trying to remember where I'd seen decent ones :mrgreen:
