creationblue said:
It's a Westy handle Paul for the reason you mention, most snap and unless you find another you will have to use a standard microbus handle, the second handle makes it easier to close in the dead of night when the usual roar of a Bay door sliding wont go down well with fellow campers :lol:
All of that noise can be avoided, by using a rear-mounted pull-close strap of "helper handle", the latter of which seem to have been relatively common, on "early-bay", USA spec. Westfalias
This is the sliding-door, pull-close strap, I made for my British specification, right-hand drive, 1973 VW Type 2, Westfalia Continental campervan.
This is made from a 25 mm (i.e. 1 inch) wide strip of duralumin and some 25 mm (i.e. 1 inch) wide nylon webbing. I used grey webbing, whose neutral colour blends well, with the pastel-white interior, but I also have, black, blue, orange and some other colours I think.
The two 20 mm long screws, use the existing tapped holes, in the sliding-door, rear hinge mechanism, as does the special OEM helper handle.
The main sliding-door handle, is obstructed by the campervan furniture, so this strap mades it much easier to close the sliding door and much quieter too.
If anyone is interested, I have some some materials left, to make up some more, for either right-hand or left-hand sliding doors.
