purplecampervan
New member
hi all, does anyone know what the static timing should be for the first start of a 2332 motor? it is all new with 044 heads ,engle 120 cam, 48idas. it has a bosch 009 with ignitor in it. Question - There is a degree pulley on that has all the numbers on it , with this lined up with the split on the crank case showing the correct ?timing - ignition on , no1 lead removed with a spark plug touching earth, I think if I slowly turn the dizzy until it sparks then all should be well? any advice will be really appreciated thankyou.
