Evening all,
I’ve just embarked on stripping my steering box as it isn’t in a particularly good way with the amount of play in it at the straight-ahead position. I’ve managed to get hold of an OG steering pin, so thought it’d be no harm to chuck this in, however, it seems someone has been in there before and fitted an aftermarket one-piece pin, so I’m not sure on what parts are missing.
Below are photos showing the OG pin loosely fitted in the arm which just is the two pin parts, and the washer. Next to it is the one-piece with a variety of washers and the locking tab.
I know I need the locking tab washer, but should there be any other spacers etc?
As an aside to this, I have found that the steering pin was not adjusted properly - it was far too tight and wasn’t rolling up and down the worm, so at least I know I can sort this. The worm looks ok to me, but then I’m not entirely sure on how ‘bad’ a bad worm would be visually. Will be looking for other sources of wear (and potentially look to have the case machined and bushed) when I do a dry assembly before it gets a lick of paint.
Stay tuned as this thread may turn more extensive…
