Similar to VW engines the flywheel/crankshaft oil seal is an area that can be prone to leak at a certain mileage - so when the engine is out it makes sense to replace it.
However to get to it I had to remove the nasty and in parts melted old flywheel that came with the engine. It wasn’t getting reused
With the flywheel off I could see the oil seal has been seeping so out it came - and again in this area some engines have a plastic plate instead of a metal one that is prone to cracking.
With it removed it was time to give the area a good clean and wipe down and fit a nice new part.
The reconditioned flywheel had a new pilot bearing installed and was reinstalled to the engine.
The brand new clutch and reconditioned pressure plate were also installed and torqued to spec
To sum up if I can remember it all the engine has had:
Gates Cambelt Kit Inc all ancillaries
Gates Waterpump
Subaru Oil pump seal
Bosch Spark Plugs
Subaru Spark Plug seals
Custom HT Leads
Subaru Water manifold O-Rings
Felpro Inlet manifold Gaskets
Felpro Headgaskets
Subaru Crank Sensor
Subaru Cam Sensor
VDO Oil temp sensor
VDO Oil Pressure sensor
Subaru Oil filler O-Ring
Subaru Rocker cover gaskets
SmallCar Performance Sump inc oil pickup
Subaru Crankcase oil seal
Subaru Exhaust studs all of them
Custom Alternator belt
Subaru Harmonic pulley
New fuel lines (PTFE Braided)
Reconditioned flywheel
New blueprint clutch plate
Reconditioned pressure plate
Subaru New Flywheel pilot bearing
Blueprint Oil filter
Various nuts and bolts that had become corroded or rounded off over the years
Fairly comprehensive and expensive list of parts never mind the paint and time spent.
At this point I was starting to appreciate perhaps why the professional conversion companies cost so much
With the engine pretty much wrapped with mostly new components it was time to start on the gearbox
