Today i had to made two large investments but it was worth it
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
First I picked up the bus at Bus Brothers, where they did some adjustments and repairs.
First of all they loosened all the ball joints of the steering mechanism which were pressed much too tight and the mounted them in the right way. Two had to be renewed.
The steering damper was functioning very hard and is also renewed, then the car is realigned.
Further on, the ignition is adjusted, it was found that the sparking was much too early and the mechanical device to get the ignition earlier with higher revs (I don't know the English word) did not work at all.
This is disassembled and was heavily corroded. So, it is cleaned and it could be made functioning again.
Also, a part in the (revised) carburetor was not installed properly so the fuel spurted in all directions but not in the right place. It has been renewed and adjusted. The valves also had to be readjusted, because they were much too tight.
Altogether, more than 11 hours of work and the necessary new parts mounted.
But on the way back home I have driven with a grin because for the first time I could drive relaxed without having to correct the steering all the time. The engine does idle beautiful now and has much more torque than before.
Then I brought back the borrowed chair to Mister Sam to pick up my new door panels and my re-upholstered chairs. These are truly beautiful now! They are now partially covered with the same fabric as the rest of the interior.
Soon, I will take the bus on the road finally :mrgreen:
Old:
New:
