"The Keeper" 1970 Sacramento Westfalia Pop Top
You guys are wheely obsessed............ :wink:
Tidied up a few interior trim bits today, glued the headliner down as the rubber seal round the hole in the roof (technical term ) was not on there, gonna sort that once the glues dried. And got my tires on the wheels, slow day as baby parties took priority (keep Lisa sweet :mrgreen: )
Very nice choice. I run the deep 5.5 on my wifes beetle. I love circus wheels(oops I mean sprint stars). I can wait to see an altitude adjustment and the new wheels. How does the offset work and will they clear the rear axel nut?
X2
i love Sprints, nice choice 8)
Be a few days before she reaches the workshop for some serious work to start
in the meantime ive stripped the interior for reupholstery, and given the inside a good clean
the cab floor was a bitch, i had to sweep it and give it a damn good wash :mrgreen:
also stuck down some loose laminate :wink:
Gary, was gonna ask you, if you're fitting a narrowed beam, will you have a front camber compensator for sale?
MSN me. :mrgreen:
Nice one Gary.
Glad to see it here, looks sweet and I hope you keep this one a bit longer. It takes me back 12 Months. Hope to be parked up in the Vanfest line up....pop tops ahoy!
Let me know if you are still interested in the hinge swap, assuming you will be fitting up the Electrics the same as mine.
What tyre combo did you go for in the end?
Jon
faux said:
Nice one Gary.
Jon
Hi Jon
Cheers dude, yup electrics are in the pipeline
Aim to have it ready for action in august, and then onto vanfest
:mrgreen:
slammedresto said:
faux said:
Nice one Gary.
Jon
Hi Jon
:mrgreen:
Cool, good luck for Action and good tyre choice, see you in Malvern.
Keep the pics coming! 8)
faux said:
slammedresto said:
faux said:
Nice one Gary.
Jon
Hi Jon
:mrgreen:
any chance of some more detailed pics of your electrics jon
Right, some progress, but no pictures im afraid
New beams on after some huffing and puffing, took 3 to get it on.........lol.......bloody heavy
Figured out the rear springplates, also need to fit new rear wheel cylinder, pads etc on the rear, as its a bit leaky
also had a few probs with the brake hose adaptor on the wilwoods, as i ordered the wrong part.....dooh
Come on Gary, you know better than to keep the pictures from us!!!!!!
I bet there was less swearing puting that beam on than when I did mine.... :lol:
Love the complete set up, looks the dogs!
if i can sort out the brake hose adaptors on the willwoods tommorow, you will have some pics :wink:
rear plates and front beam is done, bar the front brakes, rears were truly shocking, falling apart literally
disaster tho........................it needs a battery tray :shock: :mrgreen:
thats it welding wise
pics tommorow i promise :wink:
im a week behind now due to brake hose adaptors, parts all ordered now i hope, aiming to have it back down on the ground and motd by friday
to do b4 mot
new clutch cable
rear brake shoe fitting kit
fit front lights
paint pop top
paint bumpers
fit front brake flexi and hose adaptors, bleed system etc
adjust height to level
order and fit rear shocks
Cant judge rear shock till i get it back down, which due to brake probs mean i havnt been able to dial in the ride height yet
not all polished yet, but OG paint is coming up a treat
rear adjustable spring plates fitted
How are you painting the pop? Mine could do with a freshen up.
Looking good Gary, good OG paint always makes me smile. :) Add some shiny new parts I just can't fault it. 8)
If you want to order rear shocks you can jack the back up to where you want it to sit and measure. This is due to the fact you will be dialing your rear to the max anyway, and without notching the rear chassis rails you are limited. You will see what I mean if you lift the rear up and look at your A arms and Drive shaft. There is only a couple of inches of movement (max) when you use the spax adjustables. You will also need to cut two thirds of your bump stops off and will only have 1cm ish of space between bump stop and plate. When you replace the shock with the spax or other lowered shock you will need to remove the lower shock bolt to get the wheels on and off.
As for the front, if you have 2 and a half inch dropped spindles I would set the adjusters to the maximum height and then move 1 to 2 teeth down. This should give you a drop that brings your tyres up into the arches. On mine I have 3 and a half inch spindles and it is set at maximum height.
Hope to see the bus in the flesh soon.
Jon
