g16stu
im constantly forgetting to remove the charger from the cigarette lighter when i leave the bus for short periods of time, my concern is that someone will see the lead hanging from the cigarette lighter and presume the tomtom is still in the bus and break in.
to resolve this i hard wired the charger to the back of the lighter in the bus and discretely routed the cable through the gap between the dash and the pillar, so that around 6 inches protrude to allow connection to the tomtom but are pulled out of sight once the tomtom is disconnected.
The tomtom charges constantly even with the ignition off and keys out.
i initially thought this was no problem since once the tomtom is disconnected it wont be drawing any current so the bus battery will stay good.
since ive installed it tho i have been thinking about the actual charging unit. the charging unit consists of various resistors a coil and other electronic bits and bobs will the unit draw current even when not connected to the tomtom itself? or is the charger only 'on 'when connected to the tomtom???? i dont want to drain the battery if the bus is stood over the week!! Any thoughts?
Does anyone leave their charging unit in the lighter permanently and if so does it drain the battery?
