Gütterßnipe
IS MY FANBELT OUT OF ALIGNMENT??????
Bit of advice if you please as want to sort this out as
It's the only thing that ever goes wrong with the Camper
My bus has a tendancy to go thru Top pulleys on a
6 monthly basis and currently I'm using
A locking washer/nut combo just to keep the thing in place!
I've got a 1600TP and it was fitted with what looks
Like a new alternator before it shipped from the States
But I've read somewhere that if you convert from
Dyno to Alternator you need to replace the back plate also???
How do I work out if this has already been sorted???
Also the alternator is made by MOTOROLA which makes me
Question things???
One thing that doesn't help us that my engine has had the
Number ground away from the case (i hear this is quite common
on US remanufactured engines) so I have no idea if it
Had a Dyno or Alternator in the first place so I guess the tinware
Isn't original either?
When I look at the alignment of the pulleys it looks to me that
The bottom pulley sits out further than the top one!
Also what size fan belt should I be using as again it's based
On the bottom pulley, how do I work this out without an engine no.??
Any help gratefully received
Spence
Question things???
Spence
