Looking to replace my fuel lines on my 69/70 bus. Previous owner fitted a 2110 engine with twin Weber 44 idfs, and has a breather box fitted on the firewall. Access behind fan is proving tricky!!
So, fuel line currently runs from my standard fuel pump, straight between the inlet manifold of left carb and side of the tinware on the fan, to a 'T' connector (located just down behind left hand carb) which splits into a short fuel to left hand carb and then longish piece seemingly along the base of the fan housing to the right hand carb.
So...
Is there an actual "suggested" route these lines should ideally take when fitting twin carbs? I.e seen some t connections mounted on engine bay roof/firewall?
Cheers!
So...
Cheers!
