shane r
Yes, new project forces the sale of my USB Westy. It's an Early Bay 1971 (tax exempt) Californian import. It had one owner from new before I got it. If you've followed the antics of the USB or VWDRC you will already know the van. It has it's interior out (except the original R&R bed) but I kept it all and it's dry stored in my garage if you want to make it a proper camper again.
Some Extras:
Custom 17.5" woodrim steering wheel, Gene Berg shifter, line lock, Flat Four polished fuchs all round (proper Porsche pattern), proper stainless exhaust (not shown in photo), recovered front seats, custom colour-matched bra from Spirit of the 50's, split charging/leisure batt system, new Blaupunkt stereo w/ remote, new propex heater etc... at least £1700 worth
The Engine:
a 2110cc Type 1 stroker with less than 500 miles. Want the full spec?
82 x 90.5mm = 2110cc Sport / Torque Engine.
CB Forged 82mm crank + 8 dowelled
crank and case hardware kit
std weight 8 dowell steel flywheel
1700lb kep cover JC
5LB steel crankshaft equalisor pulley
5500" scat forged H beam con rods
Engle FK7 camshaft with new gear (288 x 450")
Scat 1.25 ratio rocker arms
Jonson cam followers
360 degree cam bearing set
main & rod bearings ( k/s )
30mm oil pump with cnc machine full flow pump cover
AA forged 90.5 long stroke piston kit with light weight wrist pins & tru arc clips
VAG cylinder air deflectors
Manton pushrods cro-moly cut to length
Scat swivel feet valve adjusters
Autocraft shaft kit
Magnum 44 sport heads 40 x 35.5
springs shimmed to 1.5" = 235lbs at 0.450"
wb inner valve springs
new h-duty aluminium case with full flow oil return,case savers,oil galley's drilled & tapped.
case oil pressure relief valves incl dual front spring conversion
case & pump oil unions
cro-moly cylinder stud kit
copper head seal rings
barrel spacers
rocker arm spacers
rocker pedestal spacers
CB wide mouth windage oil tube set
rear case oil seal
engine gasket set
VAG oil sump plate
balance crank assembly
Massive deep sump
Facet fuel pump
Malpassi fuel regulator/guage
Dellorto 40's
Pertronix billet distributer
compression at 8.5
Total cost of engine about £5000
The van is not concourse, but it's rock solid. MoT'd until the new year sometime (will check the ticket when I get home today) but has gone through the last 3 with ease and I would expect it to do the same again.
I bought the van in 2005 for £7500. This plus the extras and engine makes a total spend on this van £14,200. It has spent most of the nasty weather under cover. Go camping, or straight into the USB, or both!!!
Priced to move at £12,000. Will consider good T25 in part ex deal. Van located near Oxford.
Some Extras:
The Engine:
1700lb kep cover JC
Autocraft shaft kit
barrel spacers
rocker arm spacers
rear case oil seal
engine gasket set
VAG oil sump plate
Massive deep sump
Facet fuel pump
Dellorto 40's
compression at 8.5
