justcruzin
fastwagens said:looking good kim. you have come a long way.
Thanks!
I really didn't want to paint the top but with the fibers flaking off of it, it had to be done!
yachty said:@ Just.......We is cool daddio's
Ozzie, was the oil all over the top of the engine? If so, my money would be on oil cooler seals or a loose oil cooler![]()
Resto-raider said:Started polishing the deluxe trim. Spot the differences
crede999 said:Resto-raider said:Started polishing the deluxe trim. Spot the differences
good result there fellawhats your method ? :msn4:
chris
Delilahtoo said:Finally fitted the Propex that was bought through the JK group buy back in November. I had been putting it off and putting it off, but with the sun shining I dived in. Fired up first time after clearing an airlock. Am I a happy camper or what.![]()
The hook up trip switches have had to be relocated as a result, seen temporarily tucked back in the top pic, but that other than that it was a fairly straightforward install.
myvanway 69 said:Delilahtoo said:Finally fitted the Propex that was bought through the JK group buy back in November. I had been putting it off and putting it off, but with the sun shining I dived in. Fired up first time after clearing an airlock. Am I a happy camper or what.![]()
Nice one, did you take your gas through the floor and back up, or take the interior out and ffed it through the units?
Nice job mate.
Paul.
Mark6455 said:Today I replaced my distributor o ring but still got pissing oil leak from somewhere any ideas as I've changed
1-flywheel oil seal(both)
2-push rod seals and tubes
3-oil cooler seals
4-fuel pump gaskets
Anything I've missed?
Mark
yachty said:Mark6455 said:Today I replaced my distributor o ring but still got pissing oil leak from somewhere any ideas as I've changed
3-oil cooler seals
4-fuel pump gaskets
Mark
Given that you've changed the dizzy o ring I assume there is oil in that area so check the case threads for the oil pressure switch? If its been over tightened in the past the switch won't seal properly
yachty said:PTFE tape, careful not to cover the hole in the switch. Plenty of wraps. I was once told by a plumber 8 wraps minimum!
Easy way to tell is if you still have threads showing on the switch, and its just slightly more than hand tight, then it's probably OK. If you can screw it all the way in with little effort the taper in the case is likely goosed. It doesn't take much. Think of it like an oil filter, hand tight and half a turn more.
