Scraping old loose stone chip from the wheel arches, wirebrushed and panel wipe and spray more stonechip then waxoyl - I've only done 1 - only 3 more to go :suicide: When will it enddddddddddddd!!!
matt69bay said:Fitted some new wheel bearings to the front end (bit rumbly after our easter break to cornwall) :shock:
aogrady said:matt69bay said:Fitted some new wheel bearings to the front end (bit rumbly after our easter break to cornwall) :shock:
Hi Matt,
Unfortunately, my bearing failed on the way to Newquay on hols last evening, shame it didn't last 48hrs, but Rich @ Restohaus sorted it this morning - top job, but severely minus on browny points with Linda now due to epic tow truck recovery
Gear linkage and brakes to faff with tomorrow
Alistair
Mark6455 said:Wished i had'nt poked around underneath my bus.
Today i went to my mates garage so he could put my new wheel bearing in so while it was up on the ramp i thought id have a poke around at the chassis and belly pans :shock: wished i had'nt now
So tomorrow ill be cutting all the belly pans off to see the real issues
more pics to follow
mark
more pics to follow
mark
Tofufi said:Mark6455 said:Wished i had'nt poked around underneath my bus.
more pics to follow
mark
Oh wow, that's the middle strengthening layer of the sill you can see there. The inner piece has completely rotted away.
That's gonna need a fair amount of work I'm afraid - but it'll be worth it in the end. If you're doing the work yourself, I'd remove one pan at a time, starting with the one that looks worst. I find each side took me several days welding, so if I'd removed the whole lot in one I'd probably have lost Mojo by not being able to drive it for a few months.
Good luck!
Mark6455 said:Thanks for the good luck wishes dude thankfully I won't be doing it myself and the thing is my mot is due on the 1st may so I won't be able to use her for a couple of weeks anyway.
I've just had a lower half respray too so that was a complete waste of time.
So now I need to look at ordering repair panels I was thinking of using schofields and what panels is it just an inner and outer on the offside also jacking points and outriggers I know I won't really know until I take the belly pan off.
Thanks for the reply
Mark
