kyb gaz-a-justs on the rear and bug pack oil filled on the front! the front ones have only been on for 24 hours so cant tell you yet whether they are good to go or not!!!!
Gaz adjustables at the front (Modified to fit narrowed beam) Spax adjustables at the back. still scrapes at the front even on the firmest setting!!
Tubs next I thinks!!
Cheapo Brazilian oil filled units from GSF. Measured a couple of different ones in the shop, these compress 50mm more than min suspension travel. About £25 the pair and they work fine. I'm far from convinced of the need for expensive gas filled dampers on vehicles with the performance of the average VW bus.
Lights blue touchpaper and stands back..........
