Wheel offset.
blondiedread
May 26, 2008
134
Skipton, North Yorkshire
So how does it work???
If a wheel is ET30 and I use 25mm thick adaptors, will the new offset be ET5 or ET55?
I have tried http://www.1010tires.com/WheelOffsetCalculator.asp" onclick="window.open(this.href);return false; but it seems backwards somehow :?
Also, how wide a tyre could I fit to a 5.5j wheel?
Thanks.
Matt.
Using the spacer you're effectively reducing the offset. Therefore I think you'd end up with ET5.
Not sure about tyres - depends on the look you want (and also the type/make of tyre I think?). You could fit a 205 but it might look a little "balloony".
Found a couple of sites that may help to explain. The second link allows you to change the ET and see how the wheels looks.
http://www.topbuzz.co.uk/info/offset/offset.htm" onclick="window.open(this.href);return false;
http://www.morfed.net/wheel-offset-calculator/" onclick="window.open(this.href);return false;
Hope this helps everyone when lloking for new wheel and tyre combo's.
http://www.tyresave.co.uk/tyresize.html" onclick="window.open(this.href);return false;
blondiedread, 5.5j wheels, i think you should be able to fit anything from 165 - 205 tyre's.
But don't quote me i'm no expert.
I have 205s on the rear (flared arch 71) on 5.5 wheels, effective offset is 25 -
ET45 wheels on 20mm adapters
