- Joined
- May 17, 2021
- Messages
- 358
- Reaction score
- 280
we've got similar brackets on the bus and on the roof - then a small strap goes through them both to hold the roof down. Here's a couple of pics, not the best, but hopefully show you location etcMy solution to hold down the roof of the bus leaves a very sharp piece of metal to get tangled on when climbing into the new roof bed.
I have a new plan and would like one of these... also, what goes on the roof to clip on this?
After my little roof off fiasco on the Severn Bridge a few years back, I too resorted to physical straps to retain my Houdini of a roof. Worked really well but became a bit time consuming when packing up from camping. I put up with it for a few years mainly using double sided fabric Velcro doing the same routine as your straps above until I could come up with a nicer alternative. I bought quite a few different types of clips and pins and toggles etc but just couldn’t manage a nice simple and quick release and attach method for ages. Eventually I cobbled together four over centre clips to hold it down which are super quick to use either upping or downing and I’m happy that my errant roof has met his match. I’ll grab a good picture later. But here’s the double sided Velcro just before it’s strapped down.we've got similar brackets on the bus and on the roof - then a small strap goes through them both to hold the roof down. Here's a couple of pics, not the best, but hopefully show you location etc
I have the same set up as Ben with 4 straps. They work really well, provided you remember to lower the roof unlike I did on a 7 mile jaunt to Tenby South Beach last yearwe've got similar brackets on the bus and on the roof - then a small strap goes through them both to hold the roof down. Here's a couple of pics, not the best, but hopefully show you location etc
Similar yes. I see Gary has some solutionsYes! That’s exactly it. I knew I’d seen it on the bus already. Also, they’re on the Westy roof to clip straps to.
This looks solid but would be overkill for this job.Here’s my over centre clips. Much more solid and much more positive arrangement altogether. Had a right pfafff getting them all to physically line up initially. This the front one behind the drivers seat O.S.F. and with the bunk cover peeled back to get to it.
Ozziedog,,,,,,,,,,took me time View attachment 7551
I'll call as soon as I can. This is just what I need.Coolcampers 07979 726763
I have these 07979 726763
