Which carbs
yachty said:
Talking about setup, a CSP bell crank linkage will seriously improve your life Fit, adjust, forget. I haven't had to mess with mine since fitting it 3 years ago. Well worth the money ;)
Oh, and get yourself a synchro meter airflow meter. Pricey but makes setup a diddle ;)
Damn spellchecker....I meant doddle! What on earth is a diddle :lol:
+1
Not quite sure you want to know what a diddle is on a public forum.... :lol:
Just to throw another one into the mix. I am running Webber 34's ICT with my 1776 and it runs sweet as. I only have a mild cam so nothing to hard core but get could performance all round.
+1
:shock: :lol: I had to look.
I´ll never be able to sing the cat and the fiddle to my kids again :lol:
I'm running a a mild 1776 in my split & have 40 IDFs with 32 venturis, 55 idles, 130 mains & f11 emulsion tubes.
It can bit boggy down low when cold but pulls like a train after 2k, I think my accelerator pumps may need a tweak.
If I could be bothered I'd change the Venturis to 30s & drop the mains to 125s as I think that would sharpen it up, but I plan a swap to fuel injection soon.
Personally I would go for the IDF as parts (jets etc) are more readily available and are generally cheaper. I think the Dellorto is probably a bit better carb though. It's also worth noting that a 36 Dell is equivalent in size to a 40 Weber, but it's the venturi size that is more important.
The emulsion tubes & the venturi's are the expensive parts so get these right first time - F11 elusion tubes are pretty much a given in 90% of VW aplications. Idle jets are almost certain to be 50 or 55 for almost all applications up to 2 litre, run as lean as possible on these without detonation to get the fuel economy as good as possible.
So as a guide for a mild 1776
Weber 36/40s
55 idle
125-135 mains
F11 emulsion tubes
30 venturi
Linkages are all much of a muchness as long as they're not the cheap & tacky type.
Gill.
+1
Cheers for info guys :mrgreen: the csp looks quality 8)
Will borrow the bro in laws airflow meter (and him :msn4: ) when it comes to setting up :lol:
This is his toy :mrgreen:
Weber 36/40s
55 idle
125-135 mains
F11 emulsion tubes
30 venturi
Gill.
Cheers gill :mrgreen: thanks for the info :D
Oh how soon are you going fuel injection :msn4: and do you plan on selling your idf's ? ;)
:lol:
I have fitted the csp bar linkage - here http://www.coolairvw.co.uk/Item/Shop_by_Manufacturer~CSP_Products~CSP_Engine_Products/CSP129942/CSP_Cross_Bar_Linkage.html" onclick="window.open(this.href);return false;
Dead easy to fit and it is very smooth in action
J.
Weber 36/40s
55 idle
125-135 mains
F11 emulsion tubes
30 venturi
Gill.
:lol:
In the next 6 months or so mate but gonna hang on to them for another motor.
Gill.
