which front clip panel is which?
giraffeinbath
Mar 28, 2007
618
70
Bath
I've been looking at a front arch cut which I have to work out what panels I need to do the lower section of the front clip. I'm having a job identifying which panels are which from the schofields catalogue. I've illustrated the cross section of the panels, can anyone tell me which from the schofeild catalogue which colour is which panel?
Pink = No. 4 - Outer front panel
Yellow = ?
Blue = ?
Green = ?
Red = ?
Or is panel no 1 below a combination of the green/blue panels which is missing from the above illustration?
I can include a picture of the cross section from which the diagram was drawn if this helps.....
3 a and 2 a are late bay
number 2 is the inner chassis bit [joined to chassis]
number 3 is the outer bit for the inner chassis
number 4 has the low indicators and number 3 outer...
I think.... ;)
No. 2 inner front panel 68 -72 is the blue, green and red sections on your picture.
If your front panel is kippered up to the indicators you will need No. 4, if not then No. 3 goes up to the crease below the indicators.
If you need to replace the yellow section then a bit of hand fabrication is necessary.
:D
Any help?
I see, I was assuming that was a single thickness panel and therefore I was missing something, but if that combines the 3 then yes that makes sense :)
