Windscreen wiper switch bypass Early Bay 1968?
Motor appears to work fine after I removed it from the vehicle. (both speeds work fine). Motor also works fine when attached to spindles etc.
When I put the motor back into the vehicle and connect up to switch it still works fine. (switch is not fastening to dash at this point)
However, when i put the switch back into the dash as soon as I turn the wiper on it blow the wiper fuse?
Any ideas?
Sounds like you have a wire on the wrong place so a feed is grounding out.
Thanks gents. I had 31 and 31b on the wrong terminals on the switch. All working as expected now.
Thanks again for all the advice.
