BRAD
Everything is going wrong lately and the list is getting longer
Now I have condensation on the carb and frost on the inlet, both are freezing
Had a look, removed carb, fitted new gasket, couldn't fit spacer as it made the studs not long enough :evil:
Ran it, it was fine for about three minutes, then high pitched whistling and freezing cold even after ten minutes of idle.
wtf :?:
I'm thinking blocked heat riser or something.
wtf :?:
