It's now time for me to start building up the engine for my 72 baywindow.
Parts list he has so far:
AS41 case,standard size bearings (machined for full flow)
90.5 barrels
Stock balanced 311 rods
Lightened flywheel and balance bottom end 69mm crank,8 dowel.
2x40 Italian Weber IDF Carbs
Meling high flow oil pump
Oilcooler and filter
Stock heads and valves
bugpack 1.25 ratio rockers
Engle 110 cam
009 distributor with Petronix Ignitor 2
Petronix Flamethrower 2 Coil
Any suggestions if this lot would be OK for a reliable motor and with some performance for when its needed.
It would be greatful to hear what you all think.
Thanks in advance.
90.5 barrels
Engle 110 cam
Thanks in advance.
