VeeDubMan
Thinking of taking the plunge and building a small stroker motor as, fully loaded, my '71 Dormobile isn't too happy with those Devon hills!
Currently, the engine is a 1584cc, Engle 100 cam, stock heads, cromoly push-rods, twin Weber 34ICT's, electric fuel pump + Filter King, stock 26mm oil-pump. Engine case is a new AS41 that is full-flowed, external filter and cooler.
Keen on low-down torque (to get up those hills) as opposed to out and out top speed, but cruising at 70mph would be nice. They'll be a matched gearbox in the equation too (suggestions on spec for this welcome too). Would like to re-use the 34ICT's if I can (re-jetted etc. for the engine spec - 29 venturi).
Crank: 76mm (any preference on spec/manufacturer/journal)?
Crank bearings: ?
Rods: ?
Rod bearings: ?
Cam: got Engle 100. Is this OK?
Cam bearings: got dual thrust at the moment
B&P's: 90.5 Mahle (I guess)
Piston Rings: Total Seal
Heads: Stock, machined for 90.5? - port and polish...valve sizes? Stock?
Compression ratio: around the 7.8:1 mark
Sump: deep sump needed?
Carbs: would like to re-use the 34's. 29 Venturi has been suggested (thanks @atafonso) but what about jet sizes?
I'm after a shopping list basically which I can then tick off
I want to enjoy driving my van this summer without worrying about hills and speed too much.
Thanks in advance
Crank bearings: ?
Rods: ?
Rod bearings: ?
Thanks in advance
