Getting there bit by bit
Both spindles and breaks built up
Then put the Gabriel's on, u fitted the small gauge pipe just so I could pump them up with a hand pump as I haven't fitted the compressor yet.
All pipes will be replaced with 6mm and nice push fit fittings.
And then a quick look at my ride height so I can start to dial it in.
Cheers Darius, as you know I wanted a -4" beam but T2D no longer sell them and It would have been a bit tricky with the Gabriel shocks as they are very wide.
*Note I'm not using this pipe work it was only to inflate shocks enough to fit them.
A couple more pictures from today.
For anyone wanting to know the spec I am running.
T2D dropped spindles
T2D 3" narrowed adjustable beam
T2D lift arm modification to the lower trailing arms
Gabriel hi jackers model no 49230
Air lift compressor model no 25655 control system and on board compressor.
15" split screen wheels powder coated in RAL Signal White
165/55/15 Nankang AS-1
185/65/15 Nankang RX615
